LMS 2.5 and ACL Manager 1.6
Oct 26th, 2007
We are running LMS 2.5.1 an we are trying to install ACL Manager 1.6. The install of ACL Manager runs fine and all files are loaded in the correct directory. However, when you open CiscoWorks there is no listing for ACL Manager.
Is ACL Manager compatible with LMS 2.5? We were told at purchase that they were compatible.
Joe Clarke Sun, 10/28/2007 - 14:27
You cannot install ACLM with LMS 2.5 and higher. Trying to do so will break LMS. ACLM is a end of life product. Most of its functionality was rolled into the Cisco Security Management Suite.
