Intercluster trunk problem
sdeal
I have a trunk (Non-gatekeeper) between the legacy CCM 4.12 system and the new CCM 6.0. The trunk on the CCM 4 has the SUB then PUB listed, same on the CCM 6 side. Calls flow from the CCM 4 side to CCM 6 side no problem. Calls do not work from the CCM 6 to the CCM 4. Now here is the interesting part. This was working when I only had the PUB running on the CCM 6 side. I just added the SUB. So, I changed the server group to have the SUB listed first and moved the PUB to second. But I have updated the trunk config to match. But if I move the PUB up in the list and leave everything else the same and do a reset everything starts working again.
Not applicable
Do you face any issue in calls between the clusters?
cristian.munoz
Level 4
Level 4
I have the same problem. Do you solved?
I have the same problem with the ICT.
from a single CCM 6.0 to a 4.2 cluster works fine, but not the other way.
Do you resolved your problem?If yes what you changed?
Did you resolv the problem, i've the same problem between 4.1 and 6.1
