Stretched VLAN
Oct 26th, 2007
I'm trying to setup a stretched vlan between two of our sites, but am having little joy.
I have a 2600 router at each site with the fa0/0 interface connected to a 100Mb COLT line.
The fa0/1 interface on each connects directly to a trunked switchport on a 3750 switch.
Basically, I want to create a vlan with an ID of 50 which spans both sites.
I've tried allsorts, but am drawing a blank.
Any help would be much appreciated.
Thanks in advance...
Campbe
Overall Rating: 5 (1 ratings)
pstebner1 Fri, 10/26/2007 - 08:55
Hi-
You have to use bridging to do this. If I recall, this is similar to the syntax you would use on each router:
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
Int fa0/0
no ip address
int fa0/0.50
encap dot1q 50
no ip address
bridge-group 1
int bvi1
ip address xx.xx.xx.xx
HTH,
Paul
campbell.thomps... Mon, 10/29/2007 - 04:27
Paul,
Thanks so much for your reply. I think I'm nearly there, but I have one more question for you...
The detail below is how I have my interfaces setup on the routers at each side:
ROUTER A:
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.50
encapsulation dot1Q 50
bridge-group 50
interface FastEthernet0/0.254
encapsulation dot1Q 1 native
ip address 10.0.254.25 255.255.255.248
interface FastEthernet0/1
ip address 10.1.254.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1.50
bridge-group 50
interface BVI50
ip address 10.1.50.28 255.255.255.224
ROUTER B:
no ip address
speed 100
full-duplex
bridge-group 50
ip address 10.0.254.26 255.255.255.248
ip address 10.2.254.1 255.255.255.0
ip ospf network broadcast
speed 100
full-duplex
bridge-group 50
interface BVI50
ip address 10.1.50.29 255.255.255.224
My idea is that I would segregate the traffic on to different subinterfaces to keep things simple.
Interface fa0/0 on each router is connected to the leased line. From ROUTER A I can ping the other fa0/0.254 ip address, but I can't ping between fa0/0.50 on each side...
Any ideas?
Thanks in advance.
pstebner1 Mon, 10/29/2007 - 08:10
Campbell-
The syntax is a little wrong, but that is not the issue here. In order for this to work, FA0/0 and FA0/1 have to be part of the same subnet. If they are not, you can only route across them and no VLANs will route this way.
Maybe a picture might clear this up for me if I am misunderstanding something.
Paul
campbell.thomps... Mon, 10/29/2007 - 08:36
Paul,
I've sent you a basic diagram (hope you have visio). Basically, I want to stretch the vlan50 from site 1 to site 2 so that I can ping between the two. The setup you see for the switches and routers is as you see them in the diagram and I think the config is fine for them as I can ping the subnet on each side from the router, but can't ping between the routers (if that makes sense...)
I've obviously set the subinterfaces etc, but I'm interested to know what you would suggest from a vanilla setup.
Thanks in advance.
pstebner1 Mon, 10/29/2007 - 09:17
Try this. I set this up somewhere about a year ago after tring it in a lab for a week and it's really strange, but give it a try. You will only be able to manage the routers using the IP address on FA0/0. Also, you MAY have to change the mask on vlan 254 to be /8 instead of /24.
Router A
bridge irb
bridge 1 route ip
int fa0/0
no ip address
bridge-group 1
int fa0/1
no ip address
speed 100
full-duplex
vlan-range dot1q 1 254
exit-vlan-config
bridge-group 1
int bvi1
Router B
bridge irb
bridge 1 route ip
int fa0/0
no ip address
bridge-group 1
int fa0/1
no ip address
speed 100
full-duplex
exit-vlan-config
bridge-group 1
int bvi1
Let me know how/if it works out.
HTH,
Paul
pstebner1 Mon, 10/29/2007 - 10:45
What IOS version are you running? That command was introduced in 12.3(2)T
campbell.thomps... Mon, 10/29/2007 - 10:52
Here's what 'sh ver' gives me...
IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(23), RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 24-Jul-07 15:44 by stshen
Image text-base: 0x80008098, data-base: 0x81ABF658
ROM: System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-I-M), Version 12.3(22), RELEASE SOFTWARE (fc2)
LONPNWRTR01 uptime is 7 hours, 3 minutes
System image file is "flash:c2600-is-mz.123-23.bin"
cisco 2621 (MPC860) processor (revision 0x200) with 61440K/4096K bytes of memory.
Processor board ID
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
pstebner1 Mon, 10/29/2007 - 11:14
As far as I can tell you need to put on a 'T' version to use this command on 12.3. I think that all 12.4 releases allow this. 12.3.14T7 is the latest one available for the 2600 series, at least. I set this up on a 1721 running that exact version.
Any chance that you can replace your IOS?
