FWSM Rule Allowing NFS
Oct 26th, 2007
Is there a way to creat a rule to allow NFS through the FWSM? From what I understand about NFS there is a complication with the port mapper and the dynamic UDP ports.
Anonymous (not verified) Thu, 11/01/2007 - 11:45
NFS over UDP will creat alot of fragments. The FWSM has a limit of 15000 fragments per second
dtabera Wed, 11/07/2007 - 03:51
You have to open the RCP port (tcp/111 and udp/111, I guess. However, in the ACLs you can use 'sunrpc') and activate the inspection, if it is not active by default:
policy-map CSM_POLICY_MAP_global_3
class CSM_CLASS_MAP_1
inspect sunrpc
