Allowing VPN subnet access to DMZ
Answered Question
Oct 26th, 2007
I need to allow users from our VPN subnet access to a webserver on our DMZ.
Both the inbound ACL's are correct, but I am unsure of what the translation would be.
Our VPN subnet is 172.16.140.0/24 and our DMZ is 172.16.110.0/24
Any help would be appreciated. BTW, this is an ASA5510
Correct Answer by acomiskey about 9 years 7 months ago
access-list No-NAT-DMZ extended permit ip 172.16.110.0 255.255.255.0 172.16.140.0 255.255.255.0
nat (DMZ) access-list No-Nat-DMZ
You had the acl above in your No-Nat acl, but that is the nat exempt for the inside interface. That acl would never match. So you simply have to create a nat exemption for the DMZ with the appropriate acl.
Overall Rating: 5 (1 ratings)
acomiskey Fri, 10/26/2007 - 10:19
  • Green, 3000 points or more
Posting the config would help, but you probably just need nat exemption for the dmz.
access-list nonat_dmz permit ip any 172.16.140.0 255.255.255.0
nat (dmz) 0 access-list nonat_dmz
Please rate helpful posts.
Correct Answer
acomiskey Fri, 10/26/2007 - 10:47
jgorman1977 Fri, 10/26/2007 - 11:05
thanks. that worked. Also, could you explain what the NAT exemption does in this instance?
Thanks again.
acomiskey Fri, 10/26/2007 - 11:10
It identifies the traffic which should be exempt from nat, or not nat'd. This allows the traffic to be part of the vpn.
