MeetingPlace Outlook Plug-in
Oct 26th, 2007
Are there any known bugs for the Outlook plug-in feature for "Check Availability" when scheduling a meeting?
I have 2 versions that have been tested and the behavior is the same where a meeting is scheduled & when checking for availability the time for the meeting is behind by 2 hrs compared to the original scheduled time in the form. MS Office 2003 is being used.
Outlook versions are 5.3.0.132 & 5.3.0.138.
The MP servers were fully patched for DST last spring and 5.3.0.132 functioned properly on DST patched work stations.
g0atbailey Sat, 10/27/2007 - 08:20
Make sure that your MeetingPlace profile has the correct time zone selected. That may be your issue.
nbassel Mon, 10/29/2007 - 10:19
The timezone is set for America/New York which is correct for EST.
The DST patching is up to date for both servers and I'm trying to confirm the functionality for the plug-in only.
Shouldn't the plug-in dynamically take the requested scheduled time and show it in the window body? It does show in bold on the left side of the window but not the body.
nbassel Mon, 10/29/2007 - 10:14
The MPWeb installed version is 5.3.333 and the config client plug-in 5.3.0.138 was generated using that updated version.
MP for Outlook is installed for front end services/scheduling form only and I'm using SMTP GW for the back end services.
I'm trying to verify whether the check availability function in the plug-in is affected by a bug but I'm not sure.
umarwaqqas Wed, 03/19/2008 - 11:19
Dear All,
I have installed the meeting place for outlook but i am not able to start its service from windows services and
also i am i am not able to view the meeting place for outlook tab in my outlook.
As i look into the event logs i see the following. Screen Shot is attached
Wed Mar 19 18:20:01 2008 DCX500 >>> mlkGSGetChange
Wed Mar 19 18:20:21 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:20:36 2008 MPDatSvc (0x15C8) Information: 03/19/2008 - 18:20 :
Replication Service Request Completed. Count=3125
Wed Mar 19 18:20:51 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:21:01 2008 DCX500 >>> mlkGSGetChange
Wed Mar 19 18:21:21 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:21:36 2008 MPDatSvc (0x15C8) Information: 03/19/2008 - 18:21 :
Replication Service Request Completed. Count=3126
Wed Mar 19 18:21:51 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:22:00 2008 DCX500 >>> mlkGSGetChange
Wed Mar 19 18:22:21 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:22:36 2008 MPDatSvc (0x15C8) Information: 03/19/2008 - 18:22 :
Replication Service Request Completed. Count=3127
Wed Mar 19 18:22:51 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:23:00 2008 DCX500 >>> mlkGSGetChange
Wed Mar 19 18:23:13 2008 MPAgent (0x14E0) Information: Updated parameters 62
Wed Mar 19 18:23:21 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:23:36 2008 MPDatSvc (0x15C8) Information: 03/19/2008 - 18:23 :
Replication Service Request Completed. Count=3128
Wed Mar 19 18:23:51 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:24:00 2008 DCX500 >>> mlkGSGetChange
Wed Mar 19 18:24:21 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:24:32 2008 MPOutlook Service started
Wed Mar 19 18:24:32 2008 MPOutlook Logging to Windows account
Wed Mar 19 18:24:32 2008 MPOutlook Adding windows account to the local adminis
trator group
Wed Mar 19 18:24:32 2008 MPOutlook Granting 'Log on as service' privilege
Wed Mar 19 18:24:32 2008 MPOutlook Loading the registry hive for the windows a
ccount
Wed Mar 19 18:24:32 2008 MPOutlook Impersonating Windows account
Wed Mar 19 18:24:32 2008 MPOutlook Creating CDO instance
Wed Mar 19 18:24:32 2008 MPOutlook Error: 0x80040154 Message: Class not regist
ered
Wed Mar 19 18:24:32 2008 MPOutlook Reverting to self
Wed Mar 19 18:24:32 2008 MPOutlook Logged off successfully from Exchange and M
eetingPlace Notification Gateway
Wed Mar 19 18:24:36 2008 MPDatSvc (0x15C8) Information: 03/19/2008 - 18:24 :
Replication Service Request Completed. Count=3129
Wed Mar 19 18:24:51 2008 MPNotify (0x150) Information:MeetingPlace connection
is OK
Wed Mar 19 18:25:00 2008 DCX500 >>> mlkGSGetChange
rrobles007 Wed, 04/02/2008 - 15:13
if you are having DST issues with MP for outlook, a new version of the CDO.DLL file needs to be installed on the outlook gateway. You can get the file from the exchange admin and have them help u load on the Outlook Gateway.
haroon.rasheed Sat, 04/05/2008 - 06:19
Thank you very much for the reply but can you please explain the process of obtaining and loading the CDO.DLL file since i think that you pointed out the right thing.
I havent loadded the CDO file because i havent found this thing in Cisco installation guide,
I will be thankfull for the cooperation
helawamry Wed, 12/22/2010 - 18:52
I have Meeting place 8 and i have installed application server S/W, i need to let the users schedule meeting from the outlook, shall i have to install the web server S/W or application server S/W is enough
