web load balancing
Oct 26th, 2007
Hi there,
Cisco used to have css11500.
I can't find anything about current load balancers , especially for web servers
Do they still have it or it's being slightly changed?
Syed Iftekhar Ahmed Fri, 10/26/2007 - 11:29
CSSs are still their Appliance type LoadBalancer. It will soon be replaced b ACE Appliance.
Other LoadBalancers Cisco has to offer (CSM and ACE) are Module based (goes into CAT 6500 chassis).
visteknetworking Fri, 10/26/2007 - 11:32
thank you for your reply.
What is the best solution based on your experience if you have any to balance web servers, let say 3 for now.
sathappan Sat, 10/27/2007 - 01:21
You can go for the CSS11501 with or without ssl acceleration which depends whether you wish to offload SSL or not.
