Unable to add extensions from web gui
Oct 26th, 2007
After threates of legal action to my predecessor, I was finally able to access the voice mail password section. Now I need to add some extension numbers to our system, I can add them usin the cli but it would be much easier if I could use the web gui. When I try to add the new extensions using the web gui, I get a message that says "add extension through web gui is not enabled". Can Someone tell me what the command string is for enabling this function. I have looked all through this site and am not finding it.
Paolo Bevilacqua Fri, 10/26/2007 - 12:24
  • Hall of Fame,
    Founding Member
Is this cme that you are talking about?
If so you need "dn-webedit" under telephony-service.
