10-26-2007 12:06 PM - edited 03-03-2019 05:28 AM
Does anyone know any way to create a common subnet in two separate datacenters with or without MPLS connectivity.
10-27-2007 08:20 AM
That depends on what you have connecting the two data centers. The most generic way I can think of is to create a GRE tunnel between the two data centers and bridge your VLAN over it. If you have a Metro Ethernet or wireless connection between the data centers, you can do 802.1q trunking and share a VLAN between the data centers that way.
Brian ": )
10-30-2007 10:44 AM
Brian,
Thanks for the response! The datacenters are connecting via AVPN MPLS. Any experience with this scenario?
thanks,
Alex
