External Antenna
Oct 26th, 2007
If I attach an external antenna to a 1020 AP, such as the ANT5959 and configure this in the WLC does this disable the internal antenna, or act as a second antenna?
dennischolmes Tue, 10/30/2007 - 05:47
Also, bear in mind that you must use both connectors to get diversity back. Use of a single antenna lead does not result in antenna diversity. The AP 1020 supports diversity on the integrated patch antennae but by a much argued method. In short, the 2 internal antennae are mounted opposite directions and when the AP chooses which side it hears the signal from, it broadcasts the reply from the same side. This can be a problem when the client is moving or in extreme, and I say extreme, cases of multipath.
mark.j.hodge Mon, 11/26/2007 - 09:59
I'm now in the implementation phase and am a little confused.
I have configured the APs to use the external antenna, but it needs the gain in 0.5 dBm units. The ANT5959 docs state I peak gain is 2 dBi. How to I work out the value to enter in this field?
mark.j.hodge Mon, 11/26/2007 - 13:30
That was my initial thought, but the difference in units still concerns me i.e.
dBi == The dB power relative to an isotropic source
dBm == decibels with respect to one milliwatt
I have tried to find more information in the Cisco docs, but without success.
john.preves Mon, 11/26/2007 - 15:43
probably wont. dB is the functionality of adding together different units that otherwise wouldn't be addable. (That's a real word in the southeastern US).
The fact that it concerns you shows you're thinking.
google or wikipedia decibel for a better understanding but dennis is correct.
