10-26-2007 12:43 PM - edited 03-15-2019 04:55 AM
I work at a school district with about 8000 phones. There are a lot of moves changes adds and so on every year. We have used BAT as much as possible but it is still slow.
Is there a program out there that any one knows of that might help us. I would appreciate any help
Jason
Solved! Go to Solution.
11-07-2007 05:24 AM
Cisco Systems has a product that will manage the adds/deletes etc via the AXL interface. The product is called Unified Provisioning Manager. There are costs associated with this product and you will have to determine whether this product meets within your budget.
10-26-2007 01:10 PM
Sounds like a good idea to write an app that uses AXL for moves/adds/changes. We might look into this as we have many customers in school districts.
11-06-2007 11:54 PM
Jason
Because every site is different, you'll be hard pressed to find a ready made solution - there are some generic frameworks like Calendra, but you'll find that the effort that with the effort that goes into the whole setup and configuration, you could as well write a software that is tailored for your needs.
With CCM5, you can synchronize end users with an active directory you get single sign on, but the rest (phones, lines, device profiles) you have to do on your own. It's not that hard though.. once we've finalized the specs, it shouldn't take longer than 2 weeks and with every application you develop, you get more effective (I've built a management app in as little as 3.5 days... if you don't have to bother with raw webservices all you have to do is collect data and create ccm elements).
11-07-2007 05:24 AM
