snmp traps
Oct 26th, 2007
I am trying to figure out the best way to configure alerts for 7609 router such that when interface pos9/0/0.1 is down I will be notified.
the router is currently configured "snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart". but when the sub interface went down, no alert was sent. in this case I think because of couple reasons.
1. the physical interface remain "up" but protocol "down".
2. the interface command "snmp trap link-status" is not configured on either the physical or sub interface. this command is not applicable to sub interface. even if it were configured on the physical interface, because the link didn't go down (only protocol down) there wouldn't be traps.
How should configure the router? Do I have to rely on other notification options such as maybe bgp neighbor loss? Please advise.
POS9/0/0 unassigned YES manual up down
POS9/0/0.1 YES manual down down
Overall Rating: 5 (1 ratings)
Pushkar Sambhoos Fri, 10/26/2007 - 22:26
The easiest way to generate the SNMP trap would be to use the RMON feature. The configuration wouldbe something as shown below.
1. Find the ifIndex of the subinterface using any of the standard snmp tools.
2. Configure an RMON event to generate a traps and the description in the trap.
rmon event 1 description "POS9/0/0.1 link up" trap public
rmon event 2 description "POS9/0/0.1 link down" trap public
3. Configure an RMON alarm to associate the events with the ifOperStatus for the pos interface/subinterface.
The possible values can be obtained from the SNMP object navigator available at
1 : up
2 : down
The assumptions are
The pos0/0/0.1 interface ifIndex is 100
The interface is being monitored every 30 secs
rmon alarm 1 30 absolute rising-threshold 1 1 falling-threshold 2 2
4. Configure SNMP appropriately to generate the traps
snmp-server community public
snmp-server host public
This should generate the traps as you want them to be generated.
You can find more information on RMON configuration at
-- Pushkar
