E1 and leased line.
Oct 26th, 2007
Hi All,
Can we say E1 an a leased-line is both are same / any difference is there.
If my company take E1 from one Service Provider then how can we get Internet, from where shall I took this service.
Experts can anybody see about it.
Naidu.
Overall Rating: 3 (1 ratings)
royalblues Fri, 10/26/2007 - 23:46
  • Green, 3000 points or more
Leased is a symmetric telecommunications line connecting two locations
It could either be E1/ T1 or DS3
If you need Internet, then you could buy a leased line (E1) which is conencted to the Internet cloud. This would mean you have a dedicated E1 link to the internet cloud. Alternatively you can even think of a DSL line
Narayan
bvsnarayana03 Sat, 10/27/2007 - 00:51
  • Silver, 250 points or more
Leased lines (LL) are available with a wide range of bandwidth starting from Kbps to high speed Mbps lines. E1/T1 are a part of it.
They can be either used to connect sites within intranet or to connect directly internet. Internet leased lines can be again be categorised as dedicated LL to a specific organisation or shared LL between a No. of companies.
So, the criteria of selection would be Bandwidth & Internet LL or intranet LL.
ilnaiduccna Sat, 10/27/2007 - 01:46
Hi Friends,
Thanks to both Narayan's for their good explainations.
Naidu.
