A wireless backup for an ADSL connections
Oct 27th, 2007
Hello!
I have an 871 at a remote site. Connection is via ADSL. The link is split into 2 tunnels, 1 Tunnel is for direct internet breakout and the other is to come accross over the WAN into my network for non-internet requests.
I want to setup IBURST to be used as a backup in case the ADSL link drops.
How do I go about doing this?
I am gone grey looking for documents that can guide me.
I have attatced a sample config for more information on my current setup.
Any assistance would be GREATLY APPRECIATED!
Paolo Bevilacqua Sun, 10/28/2007 - 09:43
If ibusrt connects via ethernet, to make it work on the 871, you need to download advanced ip services for your router. This will let you configure vlans for the 4 ports, one of them you will use to connect to wireless. After that you can use initially floating static for the backup.
