Cisco 1712: Setting up basic firewall
tobiaseichner
I have set up some ACLs already; can I use the extended firewall wizard in SDM 2.2 to set up the firewall without losing the set up ACLs ?
How can I safely identify the inside from the outside interface ? I have two interfaces named "Vlan1" and "Dialer1 {FastEthernet0}". According my understanding Vlan1 is the internal (trusted) interface.
aghaznavi
Level 5
Level 5
you can enable both the features. Advanced security features supported on the Cisco 1711 and 1712 routers include Cisco Easy VPN Server and Cisco Easy VPN Remote, Cisco Security Device Manager (SDM), Cisco AutoSecure, and Firewall Websense URL Filtering.
aghaznavi
Level 5
Level 5
Thank you :-)
