using 2 bri ports for voice
Oct 27th, 2007
I have 2 bri ports (4 channels) using callmanager express,that are used with a main number incoming, no DDI's. Does anyone know of the best way to get outbound dial-peers to use both ports?
I can only configure 1 port on the dial-peer, I have 24 dial-peers and want to avoid duplicating them so that I have 48 dial-peers.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Sat, 10/27/2007 - 05:08
Use trunk-group:
int bri x/y
trunk-group pots
dial-peer voice 100 pots
destination-pattern 9...T
trunkgroup pots
you can also apply translations to the trunk-group, change the order channels are used, etc.
