How CM knows where Unity is
Answered Question
Oct 27th, 2007
Can someone tell me how or where CallManager knows where the Unity server is? I mean, how does it know what its IP address is, or name, etc.? Im moving our unity server today from one server to another, and Im assuming CM needs to know where Unity is. Any help?
Correct Answer by Jon Nelson about 9 years 5 months ago
The pointing actually occurs on Unity through UTIM.
Thank you,
Jon
Overall Rating: 4.5 (2 ratings)
Jon Nelson Sat, 10/27/2007 - 07:19
  • Silver, 250 points or more
Unity knows where CM is through the Unity Telephony Integration (UTIM). This is a system tool located in the Unity Tools depot on the Unity server.
When you move your Unity server, you need to make sure that you have IP connectivity to CallManager. Once the move is complete, you can open UTIM and verify connectivity to your CM server(s).
Thank you,
Jon
jjoseph01 Sat, 10/27/2007 - 08:06
So you are saying that Unity knows about CM, not CM knows about Unity? Correct?
Jon Nelson Sat, 10/27/2007 - 08:10
They both know about each other. Your voicemail ports are setup in CM and when Unity comes online it registers those ports (through UTIM) to CM.
The integration is the key.
Thank you,
Jon
jjoseph01 Sat, 10/27/2007 - 08:18
Thanks, I just would have thought that you would have to "point" CM to see Unity via ip address or something. I guess not. Thanks.
Correct Answer
Jon Nelson Sat, 10/27/2007 - 08:20
Thank you,
Jon
