vpn on cisco asa
Oct 27th, 2007
Hi all, can anyone tell me when we use the wizard on the cisco asa to create a vpn tunnel, does it automatically add a nat0 statement so it no nats the given networks, and also does it do a seperate access list for the encrypted traffic, if i go onto the access lists on the firewall, should they show here, or would they show on the acl manager under site to site vpn ?
bbayer Sat, 10/27/2007 - 07:42
Hi, I am not sure of the specific answer to your question, but in ASDM under options tab>preferences>General tab is a check box - "Preview commands before sending them to the device". Check this check box and every time you hit apply it will show you a screen with the commands that it is going to send to the ASA and give you the option of sending them or not.
Give a man a fish.......
Teach a man to fish.......
I believe it does do a separate access list to define the interesting traffic for the VPN. I think it automatically adds the nat0 statement. I would check by looking at the config. You may need to add more nat0 commands if your VPN users are supposed to access the DMZ.
Brian ": )
