aaa accounts on cisco asa
Oct 27th, 2007
Hi all, is there any reason the asa will not let me create a local user account, it lets me set it up in the asdm but soes not let me apply any changes in there, can anyone help?
JORGE RODRIGUEZ Sat, 10/27/2007 - 18:05
Carl, what error message are you geting? when you create a user account under device administration you also need to configure or enable LOCAL Authentication/Authorization under Device Access > AAA access.
carl_townshend Sat, 10/27/2007 - 23:23
Hi there, basically when i set up the user in adsm its ok, but when i come to apply it, it come up with an error, and gives me the option to resend the command. also i have got authentication enabled but not authorization, i was told i dont need to enable authorization as the option for priviledge levels can be set on the user setup
