Unity 1.2 and Sevice Notification for SMTP
Oct 27th, 2007
I am having trouble setting up Device notification for SMTP. I followed the instructions in the Admin Guide but it is not working. Any help would be greatly appreciated!
smahbub Thu, 11/01/2007 - 15:31
  • Silver, 250 points or more
Workaround/Solution
Download the MeetingPlace SMTP 4.2.1.24 hot fix from the Customer Support Resource Center.
Stop the MeetingPlace SMTP and Notification Gateway service.
Run the MeetingPlaceE-mailGateway.exe to install the new SMTP gateway.
Restart the gateway machine.
This URL should help you:
Field Notice: FA00228 SMTP Gateway Stops Sending Notifications :
http://www.cisco.com/en/US/products/sw/ps5664/ps5669/products_field_notice09186a0080235787.shtml
Field Notice: FA00274 SMTP Gateway Stops Sending Notifications :
http://www.cisco.com/en/US/products/sw/ps5664/ps5669/products_field_notice09186a008023577e.shtml
PDurandjr Thu, 11/01/2007 - 17:09
Thanks for the info but this is not a meeting place problem. It is a problem with Unity sending device notifications to smtp. Does this apply to the unity problem as well? I didn't see any services on my unity box with the above mentioned services.
Thanks again!
lochinvar Thu, 11/29/2007 - 05:36
If you are going to Exchange did you set the relay correctly?
PDurandjr Thu, 11/29/2007 - 09:35
In Exchange or at the Unity server? From following the instructions I saw nothing about setting a relay.
