CUE editor 3.0.1 refuses to start?
Oct 27th, 2007
I just made a fresh install of CUE Editor 3.0.1 on my PC (WinXP SP2, Sun Java VM 1.6.03) but it refuses to start!
When I click on "Cisco CUE Editor" item on Start menu I can only briefly see splash screen and then nothing...
Tried with 3.0.2 version, same thing.
Tried downgrading Java VM to 1.5.12, same problem persists.
No error message, nothing in the Windows event log, pretty weird.
Does anyone had similar experience?
Any suggestions how to fix it?
BR,
Miodrag
nschlutter Tue, 12/18/2007 - 09:23
I had a very similar issue and was able to get around it by doing the following:
1. Remove the installed Sun JRE on my computer from Add/Remove Programs
2. Re-install CUE Editor (you'll notice at the end of the install it says something about the Microsoft JVM)
3. Re-install Sun Java software
