Compact Flash Cards in 6500 Series
Oct 27th, 2007
Hello, I have a 6506 switch using a sup720, the ios image was accidentally deleted from the bootflash. I understand its not possible to use xmodem to upload a new image, only through a flash card.
My question is can I just purchase any Compact Flash II card, is there a limit, are we forced to use Cisco's flash cards?
Thanks for the help,
lukebrennan Sun, 10/28/2007 - 15:05
So it is possible?
I'm sure others have ran into this question.
glen.grant Sun, 10/28/2007 - 15:28
To be honest compact flash is compact flash as long as you use the correct type . We have seen cisco gear come in with flash made by San-disk . The ones you buy in the computer store for $50 will cost you a lot more if ordered thru cisco , if you have some problem they just won't support you if say you have a box that keeps hanging . Use a compact flash II and format it before using it .
lukebrennan Sun, 10/28/2007 - 15:30
Makes sense to me.
Just wanted to see if anyone out there had experience.
lukebrennan Sun, 10/28/2007 - 15:48
My problem is that upon a reboot of a 6506 (1 sup720) i'm stuck in rommon. I'm not sure what happend here but when doing a listing of the sup-bootflash the following is shown:
rommon 33 > dir bootflash:
File size Checksum File name
40941680 bytes (0x270b870) 0x3dd6292b s72033-pk9sv-mz.122-17a.SX3.bin (deleted)
I'm guessing somehow that this file was deleted? Why is it still showing up, and is there a way to recover it?
If not there's no alternative to getting this back online? I don't have any flash cards available at the moment....
ssieger Tue, 10/30/2007 - 07:33
Have you tried if the "undelete" command works in rommon?. With undelete you can recover files that are marked as deleted. You need to discover the file index with dir sup-bootflash:, but i don't know if this command works in rommon.
lukebrennan Tue, 10/30/2007 - 07:37
rommon 35 > undelete
monitor: command "undelete" not found
rommon 36 > undelete bootflash:s72033-pk9sv-mz.122-17a.SX3.bin
rommon 37 >
glen.grant Tue, 10/30/2007 - 10:16
Yeah unfortunetly you have a problem if you have no bootable image in sup-bootflash or a external flashcard . Hopefully you have a spare 6500 around or in production you can copy from .
Not sure what options you have available in rommon . do a ? and see if you have any copy or tftp commands , if so maybe you can get an image on your pc and tftp or copy it onto bootflash? Really donn't know what rommon commands are available and there isn't a whole lot of info on rommon commands on CCO.
michael.welbourne Sat, 11/10/2007 - 20:58
You can also copy the image you want onto the compact flash card from a 2800 router. The router will complain that it isn't in a system format but if you ignore it and request it to copy it will copy from your tftp server anyways. I popped it in back into the 6500 and booted from Rommon and I'm back in business.
