Mail logs - [Connection Errors]
Oct 27th, 2007
Can someone please explain the cause of these errors and how to prevent these?
192.168.0.4 port: 25 details: EOF interface: 192.168.0.250 reason: network error
192.168.0.4 port: 25 details: [Errno 61] Connection refused interface: 192.168.0.251 reason: network error
192.168.0.4 port: 25 details: [Errno 60] Operation timed out interface: 192.168.0.250 reason: network error
192.168.0.4 port: 25 details: [Errno 54] Connection reset by peer interface: 192.168.0.250 reason: network error
Vinesh
Mark [CSE]_ironport Mon, 10/29/2007 - 13:21
Those are all delivery failures and the IronPort thinks it's network related.
There is little you can do on the IronPort, as those are network error, we just collect from the kernel for tcp stream.
I would look towards the network to resolve this. If you see those error a lot, support can help you debugging it a bit further.
Cheers,
Mark
Mark [CSE]_ironport Thu, 11/01/2007 - 13:38
EOF is normally returned for end of file. When you read from a network socket that mean that the network connection was terminated.
Mark
conauman Fri, 11/30/2007 - 19:25
Article 531 of the IronPort Knowledgebase explains Errno 61 as well. We also document our AsyncOS alerts in our User Guide. Hope this helps.
