Configuration Help 1130AG-VoIP-Vlans-Switch Configuration
Oct 27th, 2007
1130AG running c1130-k9w7-tar.124-3g.JA1, in autonomous mode.
VoIP - Call manager 6x, Cisco phones only,
Vlans - Open, secure data using WPA2, VoIP Vlan is using pre shared keys.
Switch Configuration - C3548xl's, C356048ps, 6509 cores
I have been looking for configuration examples to help me configure the interfaces from the 3546xl and the C356048ps switched to the 1130AG.
Configuration between the C3548xl's, C356048ps, and 6509 cores on the trunk ports for QoS.
The call Manager is on Vlan 210 and the Vlan for the wireless voice is 202.
Any suggested links would be grate, I think I have found most of it but want to be sure.
