Error message for Ca help
Oct 27th, 2007
Can anyone advise me on what is the cause of the problem (Manually install 3rd party Vendor for use with WebVPN configuration version 8.0) ?
i have follow the configuration example and found this error message via CLi
Appreciated any kind reply.
FO: Certificate has the following attributes:
Fingerprint: 713cdfee 53530e1e 06fa7a41 b78a7779
Do you accept this certificate? [yes/no]: y
Trustpoint 'xx.Entrust.TrustPoint' is a subordinate CA and holds a non self-signed certificate.
Trustpoint 'xx.Entrust.TrustPoint' is a subordinate CA.
but certificate is not a CA certificate.
Manual verification required
Trustpoint CA certificate accepted.
% Certificate successfully imported
PHS-ASA(config)# CRYPTO_PKI: Cert record not found, returning E_NOT_FOUND
CRYPTO_PKI: No suitable trustpoints found to validate certificate serial number: 469C84D9, subject name: cn=xxxx.xxxx.com.xx,ou=IT,o=xxxxxxxx,l=xxx,c=xx.
Current Certificate list contents:
Certificate 1:
SERIAL: 469c84d9
ISSUER: cn=Entrust.net Secure Server Certification Authority,ou=(c) 1999 Entrust.net Limited,ou=www.entrust.net/CPS incorp. by ref. (limits liab.),o=Entrust.net,c=US
CRYPTO_PKI: crypto_process_ra_certs(trust_point=PW.Entrust.TrustPoint)INFO: Certificate has the following attributes:
PHS-ASA(config)# ISSUER: cn=Entrust.net Secure Server Certification Authorit$
et,c=US
tstanik Thu, 11/01/2007 - 15:35
  • Bronze, 100 points or more
If you get a certificate from a trusted 3rd party (i.e. Verisign/Thawte/etc.) to install on the appliance then you shouldn't get the certificate warning pop-ups for anything that's encrypted by the SSL VPN appliance. For some certificates manual install maybe the only way. You need to check with the issuer of certificate for a such problem.
