Wrong Time on 7940/7960 Phones HELP
Oct 28th, 2007
Was today the original day the time was to fall back? We have applied all the necessary patches... The server times are all correct, but my 7940 and 7960 phones are an hour behind. The 7971 and 7941 times appear correct. Time on servers are correct, its just the time on the phones. We are in eastern time zone. CM 4.2
rob.huffman Sun, 10/28/2007 - 06:13
Hi Chris,
This was the "old" DST Sunday fallback date. I am not on site right now to see if our phones are doing the same thing :( sorry. Have you opened a TAC case? Have you tried resetting any of the 7940 or 7960 sets?
I might try changing the server time back 1 hour. This should not affect the 41's and 71's as they seem to operate independantly due to being Java based.
Let us know,
Rob
ischarcm Sun, 10/28/2007 - 06:18
Hi Rob... I had in the back of my head this was going to happen. I have not opened a case yet.. probably will attack it first thing tomorrow. I have done a reset on the phone that I have connected here at my house (thats how I discovered it).. but it didn't change anything. The time on the server is correct as it should be... (SO O.S.) is good. Its just the phones except the java based sets.
mstubbers Sun, 10/28/2007 - 09:44
My are doing the same thing. I had applied the tzedit fix. I'm in the middle of a planned upgrade anyway and can let you know if any of that fixes it. I'm upgrading my OS from 4.4a to 4.5b SR4. Servers have the correct time, but not phones.
rob.huffman Sun, 10/28/2007 - 10:33
Hi Guys,
I'm guessing that you are hitting this new Bug;
However, for the Fall time changes you MUST update the MCS OS versions due to the following defect:
CSCsh20360: Looping in System Date & Time due to Daylight saving correction:
The four software items that were required in March.
The Windows 2000 Patches that were recommend are as follows
2000.4.2(sr15) or higher
2000.4.3a(sr8) or higher
2000.4.4a(sr3a) or higher
2000.4.5a 2000.4.5a or higher
2003.1.1 2003.1.1(sr1) or higher
2003.1.2a 2003.1.2a or higher
However, you may experience this vulnerability - CSCsh20360 - in the following MCS OS versions:
2000.4.2(sr15) or lower
2000.4.3a(sr8) or lower
2000.4.4a(sr3a) or lower
From this doc;
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_field_notice09186a00807e02b1.shtml
Hope this helps!
Rob
mstubbers Sun, 10/28/2007 - 11:12
Yes, the OS updates did the trick and a reset of the phones.
ischarcm Sun, 10/28/2007 - 14:04
Is it just an os update or a CM update as well?
I have not been able to check our OS version yet but the server time remains correct I never had to modify that...it was only the phone times that went wrong. Was your OS (windows) time correct? Just wondering
Thank you
mstubbers Sun, 10/28/2007 - 14:12
Yes, I'm fairly certain the OS updates corrected it. Also, Rob's message indicates the same. In my case I went from 4.4b to 4.5 since 4.4 will be end of support as of November anyway.
Good luck!
ischarcm Sun, 10/28/2007 - 14:23
Ok I just got in remotely to see my OS and here is what it says. I'm not all that familiar with doing the OS updates so any pointers I would appreciate..
My level:
OS image 2000.4.4
OS serv release 2000.4.4aSR5
What is the download I should be looking for exactly? Do we just download the file and execute to publisher? I'm guessing we should do Publisher and all Subs one at a time? Approx how long does it take?
Thanks so much!!!!!
mstubbers Sun, 10/28/2007 - 15:04
May be a good idea to contact TAC just to verify your situation, but you are in a similar position to where I was. I had 2000.4.4aSR9 applied from previous updates. Otherwise here are the patches I applied and in this order. Bad news is the 4.5 update is 950MB to download from Cisco and took 45-50 minutes to apply to my server. Each server was about 1.5 hrs to upgrade. You need to do the PUB first, than all of your SUBs. Again I recommend you check out upgrade documentation starting at http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/osbios.htm
and downloads at
http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des
!!!!! RUN BACKUP !!!!!!!!!!!!
win-OS-Upgrade-K9.2000-4-5a.exe
win-OS-Upgrade-K9.2000-4-5b-sr4.exe
You should also check on SQL updates.
I chose the 4.5 route since 4.4 support ends Nov 07.
rob.huffman Sun, 10/28/2007 - 15:38
Hi Chris,
According to this your OS should be OK because you have 4-4a(sr5)?? I would open a TAC case here for sure. Why don't you look at the Manual workaround in this doc for the short term.
From this doc;
Hope this helps!
Rob
ischarcm Sun, 10/28/2007 - 15:44
Many thanks for everyones help!!! We will get with TAC tomorrow... I'd rather not go through pains of OS updates if we don't have to.... Its hard to get the maint time in the hospital!!!
mstubbers Mon, 10/29/2007 - 07:59
Rob,
I believe this document is not worded well, but my interpetation of it is that even if you applied steps 1-4 which include the 4.4a(sr3a) patch you still need to apply patches
"Please Note:
If you applied the four software items which were required to make a Cisco Unified CallManager system Daylight Saving Time compliant in March 2007 you will be DST compliant with Cisco Unified CallManager Database, Phone load / Device packs and JRE version listed below.
CSCsh20360: Looping in System Date & Time due to Daylight saving correction:"
The upgrade I applied did resolve my DST issue for the fall.
Cheers!
davidturner Mon, 10/29/2007 - 09:01
I am having the opposite problem. My Server time is correct and my 7940's and 7960's are correct but my 7941's and 7961's are an hour behind. Any ideas? Did I miss a patch for the phone loads or something?
mciarfello Mon, 10/29/2007 - 09:50
The 79x1 (and 7970) phones need at least 8.2(2)SR1 or above. Curious what your phone firmware is.
marcuscastellanos Mon, 10/29/2007 - 10:03
Well...
I'm currently on OS Image 2000.2.4
OS release 2000.2.7sr6
OS Upgrade 2000.2.7
Time was off... Currently I have my time on my servers set an hour behind to get the time to display correctly on phone...
Which patch do I need?
FYI here is the manual workaround that I performed...
CCM OS Manual Workaround 3.x and 4.x
On the new US DST date, Logon with sufficient privileges to CCM Windows Server (starting with Publisher)
Click Start, Settings, Control Panel, Date and Time
Adjust the time accordingly
Click on TimeZone tab
Uncheck the Automatically adjust clock for daylight savings changes
Click Apply or Ok
Repeat steps for all servers in the cluster.
Then on April 1, after 3:00 A.M., revert the changes back. This manual clock adjustment can be done by using the same method described in steps 1-4, check the automatically adjust clock for daylight savings changes and then steps 6-7 above. Note, however, that manually adjusting the clock on CallManager servers could result in a conflict in time which may produce time synchronization issues. For instance, adjusting the clock during any active call would result in incorrect call duration records. Therefore, adjusting the clock is best to be done when fewest active calls are present.
There are some workaround for this:
A) Manual DB change:
1. Using SQL, enterprise manager, access the CCM database.
Find the database named "CCM03XX" that has the hand (like share hand) on it. Go into that
CCM Database's table "TypeTimeZone" and find the time zone(s) your phones use. For each
time zone you use, update the following fields:
"stddate" to "0/11/0/1,2:0:0:0"
"dstdate" to "0/3/0/2,2:0:0:0"
2. Restart the CCM service ("Cisco CallManager").
3. If you use an NTP service, restart it as well.
4. Check your phones, the time should be correct now.
NOTE: If you have CCM failover configured you'll need to reset the phones for the changes
to take affect, the best way to do it is by resetting them from the device pool.
rob.huffman Mon, 10/29/2007 - 11:23
Hi David,
You may have the originally listed Firmware that was recommended for the Spring DST change 8.2(1) or 8.0(4)(I beleive). Of course this turned out not to work and the 7941 and 7961 phones need to be reset via ccmadmin to pickup the new time. This is until a new Firmware can be loaded.
Hope this helps!
Rob
davidturner Mon, 10/29/2007 - 13:15
yes i believe that you are correct. I am going to load the new firmware this evening.
