CRTP on GigabitEthernet
Oct 28th, 2007
Dear,
I connected cisco 3800 routers with ericsson MD110 PBX over E1 Pri. Routers are connected via satellite link and satellite receivers are connected with routers over GigabitEthernet. Now problem is that CRTP can't be enabled on gigabitehternet. When I issue command “ip rtp header-compression”, I get error message “RTP Header compression not supported for this encapsulation”. My scenario is given below:
PBX---(PRI)---3845---(Ethernet)---Satellite BOX----(VSAT)------ Satellite BOX---(Ethernet)---3825----(PRI)----PBX
Please tell me solution how I can enable cRTP so that I couldn't use minimum bandwidth on satellite link for calls. Waiting for immediate positive response…….
Best regards,
Rameez
Overall Rating: 4 (1 ratings)
pranabgaya Sun, 10/28/2007 - 08:36
hello rameez,
what encapsulation showing on int Gigabitethernet .
sh int gi-
is "Encapsulation ARPA, loopback not set" showing
pls paste the o/p of that command
rgds
pranab
rameezsardar Sun, 10/28/2007 - 10:32
Dear Pranab,
Thanks for responding. Below you can find output of sh int gig
R1#show inter gig 0/1
GigabitEthernet0/1 is up, line protocol is up
Hardware is BCM1125 Internal MAC, address is 0019.3045.c811 (bia 0019.3045.c81
1)
Internet address is 192.168.101.2/28
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is autonegotiation, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:10, output 00:00:03, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
375 packets input, 38880 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 6 multicast, 0 pause input
Dear if you have any solution, please tell me as soon as posible. Waiting...
Rameez
pranabgaya Sun, 10/28/2007 - 13:34
i tried it in one of our router and getting the same message as u.
pdar073(config)#int fa0/0
pdar073(config-if)#ip rtp head
pdar073(config-if)#ip rtp header-compression
pdar073(config-if)#^Z
Paolo Bevilacqua Sun, 10/28/2007 - 09:33
You can't enable crtp on LAN. If any saving or compression is possible, the satellite box will do for you.
Else get a satellite modem with serial interface so you can enable cRTP on that:
http://cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a893e.html
Note as a codec you may want to use iLBC codec on the GW, that is much better than other very low bitrate codecs.
rameezsardar Mon, 10/29/2007 - 01:27
Dear,
thanks for coordination. I tried to configure codec=iLBC but it is not working properly. When i use command "code ilbc" with default mode and call from one phone to other, recieving phone rings just one bell and call drop. If i issue command "code ilbc mode 30", phone rings bell and when i pick up the phone, call connects but no voice travel across phone. I also tried commands:
dial-peer voice 1 voip
rtp payload-type cisco-codec-ilbc 102
codec ilbc mode 30 bytes 200
but problem still there. Now tell me the solution. Waiting for immediate response.
Paolo Bevilacqua Mon, 10/29/2007 - 04:28
please configure ilc also on the terminatig router. That is a DP configured with "incoming called-number X..." and codec ilbc.
rameezsardar Mon, 10/29/2007 - 21:18
Dear, same result, when i dial number phone rings bell but as i pick up handset, call drop......
rameezsardar Tue, 10/30/2007 - 05:54
R1#show run
hostname R1
boot-start-marker
boot-end-marker
card type e1 1 1
logging buffered 51200 warnings
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
isdn switch-type primary-qsig
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice service voip
qsig decode
username cisco privilege 15 secret xxx
controller E1 0/0/0
controller E1 0/0/1
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
vlan internal allocation policy ascending
interface GigabitEthernet0/1
ip address 192.168.101.2 255.255.255.0
duplex auto
speed auto
media-type rj45
no keepalive
interface Serial0/0/1:0
no ip address
interface Serial1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn timer T203 30000
isdn timer T310 60000
isdn overlap-receiving
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip route 192.168.102.0 255.255.255.0 192.168.101.1
control-plane
voice-port 1/0:15
dial-peer voice 3 pots
destination-pattern 3...$
port 1/0:15
forward-digits all
dial-peer voice 20 voip
destination-pattern 2...$
session target ipv4:192.168.102.2
codec g723ar53
end
R1#
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
card type e1 1 1
no aaa new-model
ip cef
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice service voip
qsig decode
controller E1 0/0/0
controller E1 0/0/1
controller E1 1/0
controller E1 1/1
ip address 192.168.102.2 255.255.255.0
duplex auto
speed auto
media-type rj45
no keepalive
no ip address
encapsulation hdlc
no cdp enable
ip route 192.168.101.0 255.255.255.0 192.168.102.1
control-plane
voice-port 1/0:15
dial-peer voice 2 pots
port 1/0:15
forward-digits all
dial-peer voice 30 voip
session target ipv4:192.168.101.2
codec g723ar53
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
end
R2#
Note: Due to Character limit, i removed unnecessary information.
No VPN no fW between routers. I configured ilbc, but response as i told in last posts. Waiting.
Rameez
pranabgaya Wed, 10/31/2007 - 02:44
can u add
"voice rtp send-recv" and "voice call send-alert" on both routers .
run" deb isdn q931 " on router to find out the possible call disconnect reason.And hows the bw usage for data when u place a call , check it on source and destination router.
Paolo Bevilacqua Wed, 10/31/2007 - 06:11
Hi, this is due to codec mismatch
as mentioned above, please configure a incoming DP matching the desired coded:
dial-peer voice 444 voip
incoming called-number 3...
codec ... (or use a voice-class with the accepted codes)
