Help for E.164 Help for E.164 Help for E.164
Oct 28th, 2007
Dear i need to configure E.164 format how? now i don't have a gatekeeper just a gateway....
so can i do the E.164 Registeration?
my current configuration as follow:
dial-peer voice 100 pots
destination-pattern .T
translate-outgoing called 1
port 7/0:D
dial-peer voice 101 pots
translate-outgoing called 2
port 7/1:D
dial-peer voice 102 pots
incoming called-number 63......
direct-inward-dial
forward-digits extra
dial-peer voice 200 voip
destination-pattern 63......
session protocol sipv2
session target ipv4:55.55.55.1
codec g711ulaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 103 pots
incoming called-number 87......
direct-inward-dial
dial-peer voice 201 voip
destination-pattern 87......
codec g711ulaw
VoiceGatewa(config-dial-peer)#destination-pattern .T
VoiceGatewa(config-dial-peer)#port 7/0:D
VoiceGatewa(config-dial-peer)#register e164
ERROR-register-e164: Dial-peer destination-pattern is not a full E.164 number
VoiceGateway#sh gateway
H.323 ITU-T Version: 4.0 H323 Stack Version: 0.1
H.323 service is up
This gateway is not registered to any gatekeeper
what i need to cmplete my task?
pranabgaya Sun, 10/28/2007 - 09:24
looking at voip dial-peer , its SIP service want , not h323
can u clarify ur Q .
tareqrebhi Tue, 10/30/2007 - 01:55
Dears,
I have this problem:
I configured my AS5400 as my voice GW and it is running well….now I have calls from and to other International carriers with prefix (962) and I can see my Destination prefix in my CDR please see attached Carries file.
My problem with AS5400 for calls from & to my LOCAL national telecom company called (JT) that if I have call from JT to my Softswitch (has number 43000000) or vice versa I could not see the prefix in my CDR please see Jordan Telecom file for details, but the calls are running well with customers just I need to create and add the prefix (962) to my local calls here in Jordan (from JT to my Softswitch or vice versa) remember my international calls have the right prefix in the CDR so no problem with…just my problem with local calls.
Example:
1. International call is running well.
Dialed number Destination prefix
33497231267 33
2. National call is not running well there is no prefix 962 for this call I need to appear and let AS5400 to send it to my Billing system.
Dialed number Source number
43000001 65511096
65511096 43000001
I need for records to have my prefix 962 with all records:
962- 43000001 962- 65511096
962- 65511096 962- 43000001
any suggestions?
thank you.
