Frame-relay Hub-and_Spoke
Oct 28th, 2007
Hi,I'm working on a SIM to create Hub-and-Spoke; After configuration I can ping all sub-offices from central-office; but all sub-offices can't ping each other; I tried to enable Inverse_Arp for all interfaces, but still didn't work; Is something wrong with this SIM?
Edison Ortiz Sun, 10/28/2007 - 07:59
  • Hall of Fame,
    Founding Member
Did you implement dynamic -or- static routing ?
The spokes only know how to reach the hub, not other spokes. Static or dynamic routing will solve this issue.
learnerkang Mon, 10/29/2007 - 05:05
Thanks a lot. Yes, it works when I apply routing protocols
