CCM 5.04 Disaster Recovery regular backup stos after a week
Oct 28th, 2007
or two. Backup scheduler has default, i.e. weekly configuration, from tuesday to saturday at 2 a..m.. The backups looks OK. No error message is reported neither in the "Disaster Recovery System Backup History", nor in the CCM System Log or Application Log when the regular backing-up stops.
When I open disaster recovery scheduler screen, and save its setting without any change using "save" button, the regular backup works again - for another week or two.
Do you have any idea where to look for the reason why the regular backup stops?
craiglcve Sun, 10/28/2007 - 09:57
You could install the RTMT tool if you havent already and pull the traces or you could view them via the command line
For the Master Agent, the trace file is platform/drf/trace/drfMA0*
For each Local Agent, the trace file is platform/drf/trace/drfLA0*
For the GUI, the trace file is platform/drf/trace/drfConfLib0*
Hope that helps.
Craig
fopravil Mon, 10/29/2007 - 00:35
Hi Larson,
thank for fast reply.
I have the RTMT tool installed and I have downloaded the trace files several times already. I have not mentioned it on purpose - I do not understand content of these files at all, there is a lot informations in there and no clue. And there are no messages in these files for days, when the backup did not run.
Thank you for reminding the trace files, anyway.
Regards Frantisek Opravil
