Add phone
Oct 28th, 2007
Hello
I have call manager 4.1.3 and i want to register ipphones 7961 that i don't retrieve in the supported ipphone list
How i can register these phones
Thanks for your help
Rob Huffman Sun, 10/28/2007 - 10:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Malek,
Support for the 7941 and 7961 was not added until CCM 4.1(3)SR1. So you will need to migrate to at least this SR;
Supported CallManager Versions
The Cisco IP Phone 7961G and 7941G firmware is supported on these Cisco CallManager versions:
Cisco CallManager version 4.1(3) SR1 or later
Cisco CallManager version 4.0(2) SR2b or later
Cisco CallManager version 3.3(5) SR1 or later
You should install the following device packs for these Cisco CallManager versions.
4.1(3) SR1 ciscocm.4-1-DevPack-23.exe, or later
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_release_note09186a00804fcab9.html
Hope this helps!
Rob
