IOS Question (tar vs. bin)
Answered Question
Oct 28th, 2007
I am going to be upgrading the IOS on a few of my 2950's. On the Cisco software download section there are these two options: .bin and .tar files. The tar file has a "web based device manager." Is this the same as CNA? Any other difference between the two files?
Thanks!
Correct Answer by lgijssel about 9 years 6 months ago
The .bin is the bare image that you need to operate the switch. The .tar file also contains this .bin file and an additional set of html & other files that are needed to configure the switch via a web browser.
I assume that CNA also uses this browser interface but it is not exactly the same.
regards,
Leo
Overall Rating: 4.5 (2 ratings)
Correct Answer
lgijssel Sun, 10/28/2007 - 12:08
  • Red, 2250 points or more
regards,
Leo
