Call manager 5 installation failure
Oct 28th, 2007
Im having the preinstalled server and during startup i gave few general parameters and now it is not proceeding saying 'installation failure'.how shall i proceed???
system requirements are met.
Thanks in advance.
Overall Rating: 3 (1 ratings)
shaishav.parikh Mon, 10/29/2007 - 00:08
I found similar problem in recent past while 5.1 installation and i have formated again with recovery disk and done reinstall again , while reinstallation again pl allow media check option enable
Thanks and regards
Shaishav Parikh
deepa_network Mon, 10/29/2007 - 00:51
Thnxs ..That is the only thing i guess i can do.
I will certainly try ,hope it works!
Any valuable tips i should make sure ..i have to check so that i dont repeat the same mistake again?
