10-28-2007 11:44 PM - edited 02-21-2020 03:20 PM
I have spent days on this and I am at a loss, I cannot get this tunnel up.
Two 837 Routers at remote sites, customer wants VPN between sites.
I followed the tutorials, i turn on the debugs and ping from each site, yet i see absolutely nothing happening on either.
crypto isakmp key 0 MYKEY address XXX.248.2.94 no-xauth
crypto map SDM_CMAP_1 4 ipsec-isakmp
set peer XXX.248.2.94
set transform-set SDM_TRANSFORMSET_1
match address 104
access-list 104 permit ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 106 deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
SDM_CMAP_1 assigned to dialer
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
Both sides are a mirror, yet i cannot see any activity at all. I can ping each routers outside.
I appreciate any help, thanks
10-29-2007 01:14 AM
It would help if you could post full configs in case NAT is an issue but the first thing to note is what is access-list 106 ?.
Each side should mirror each other generally but your access-lists that define interesting traffic need to be flipped ie.
on router1
on router 2
access-list 106 permit ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255
However i can't tell whether this is an issue as you have only posted partial configs. Could you post full configs please.
Jon
10-31-2007 05:30 AM
Hello, Your suggestion saying it was NAT or ACL pointed me in the right direction. I reworked them and followed a Cisco Doc.
Cisco Document ID: 14144
It did the trick, but, I still do not understand why all the other tunnels work fine on the router and just this one has NAT issues...
Thanks for the help.
