pix as a hop
Answered Question
Oct 28th, 2007
hi,
could a pix firewall shows as part of a hop on a tracert?
if not, any reason about it.
coz we have done a tracert on a machine accross a pix and it bypasses the pix as a hop.
thanks
Correct Answer by Jon Marshall about 9 years 7 months ago
From lab setup
R3(192.168.12.2) -> (192.168.12.1) R1 (192.168.10.56) -> (192.168.10.1 - outside) Pix (192.168.0.99 - inside) -> (192.168.0.42) R2
I allowed icmp from outside to the inside address of 192.168.0.42.
From R3
R3#traceroute 192.168.0.42
Tracing the route to 192.168.0.42
1 192.168.12.1 0 msec 0 msec 4 msec
2 192.168.0.42 0 msec 0 msec *
R3#
So a pix will not show as part of a traceroute. It doesn't bypass the pix as such it still has to go through the pix but the pix does not respond.
Jon
Overall Rating: 3 (1 ratings)
Correct Answer
Jon Marshall Mon, 10/29/2007 - 04:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
From lab setup
From R3
R3#
Jon
royalblues Tue, 10/30/2007 - 12:59
  • Green, 3000 points or more
I think if you allow ICMP to initiate from inside, then the pix certianly shows as a hop
i.e if we do a traceroute from R2 towards R3 then we will see pix as a hop
I do not have a lab to set this up but i have seen the pix ip as a part of trace in the above scenario.
Narayan
