no show-tech option
Answered Question
Oct 29th, 2007
We have device that we need to get a show-tech but I don't see it as an option. Can someone please let us know if we can get it another way?
spdum01s02> (enable) show version
WS-C5500 Software, Version McpSW: 4.5(13a) NmpSW: 4.5(13a)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Feb 4 2002, 17:02:59
MCP S/W compiled on Feb 04 2002, 16:59:42
System Bootstrap Version: 5.1(2)
Hardware Version: 1.3 Model: WS-C5500 Serial #: 069033583
Correct Answer by andrew.burns about 9 years 9 months ago
The "show tech" didn't appear until a later release on the 5500 switches. Without it all you can do is just go through all the available "show" commands, like "show system", "show memory", etc. Which is pretty much all the "show tech" does anyway.
Andrew.
Overall Rating: 4 (1 ratings)
Correct Answer
andrew.burns Mon, 10/29/2007 - 03:18
  • Gold, 750 points or more
Andrew.
