configuring AS5300
Oct 29th, 2007
i have configure AS5300 below is my configuration when i recived a call from customer with 44xxxx my GW connected to BT network it strip 44 sends calls to BT where is loccaly recived to send call out side BT network they said i ihave to send the isdn # 01612260466 to BT which i did usin prefix command in dial-peer ports , but my call does not go outside BT . what i am doing wrong any help ?
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable secret xxx
enable password
resource-pool disable
no aaa new-model
ip subnet-zero
isdn switch-type primary-net5
voice service pots
voice class codec 3
codec preference 1 g729r8
codec preference 2 g723r63
controller E1 0
framing NO-CRC4
clock source line primary
pri-group timeslots 1-31
controller E1 1
framing NO-CRC4
controller E1 2
controller E1 3
framing NO-CRC4
interface Ethernet0
no ip address
shutdown
interface Serial0:15
no ip address
isdn incoming-voice modem
no cdp enable
interface Serial1:15
no ip address
no cdp enable
interface FastEthernet0
ip address
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0
no ip http server
access-list 100 permit ip host any
voice-port 0:D
voice-port 1:D
dial-peer voice 2 pots
description Dialpeer specific description
destination-pattern 44T
progress_ind setup enable 3
direct-inward-dial
port 1:D
prefix 01612260466
dial-peer voice 1000 voip
incoming called-number .
voice-class codec 3
dtmf-relay rtp-nte
line con 0
line aux 0
line vty 0 4
password
login
end
paolo bevilacqua Mon, 10/29/2007 - 04:30
  • Hall of Fame,
    Founding Member
Please collect "debug isdn q931" to understand why the call is failing.
sohail-khan Wed, 10/31/2007 - 05:48
thanks bevilacqua ,
for your reply i am sending you the log for q931 debugging . i am thank full for your help.
