CCM Time, Different than Phone Time
Oct 29th, 2007
All, Since the DST change, on 10.28 when the DST was taking place, my phones changed back 1 hour, but our servers kept the correct time. We have tried to reset the phones and the time is still 1 hour back. We are on CCM 4.1.
Any ideas on how I can fix?
rwamstutz Mon, 10/29/2007 - 05:22
John,
As a quick fix on both the publisher, I unchecked the "Automatically Adjust clock for daylight savings changes", then reset the time to what it currently is to be. Most phones "re-sync'd" others I reset.
FYI..............
kc-ussugar Mon, 10/29/2007 - 06:49
Same problem here, even though I'm at 4.5aSR2 (which was current as of not-too-long-ago). CCM is 4.2(3)
My workaround was to put all phones into the next time zone east of here.
It would be nice to get some concise instructions, and I don't think those are going to come from CCO, based on what's been published so far.
DHendo0311 Mon, 10/29/2007 - 07:48
We have found that a soft reset of the phone (794x) synchs the phone with the publisher to pull the correct time after reboot. Running CCM 4.2.3
Soft reboot:
Settings
then quicky press:
