ACS SE: back-up from private key (.pem) possible?
Oct 29th, 2007
Is it possible to back up the .pem (private key) from the ACS SE Appliance after generating a Certificate Request?
Otherwise, if the ACS SE is crashed and you reboot it with the Recovery CD, it is necessary to re-request a new certificate in stead of re-using the previous one (that can be backed-up).
somishra Tue, 10/30/2007 - 01:15
There is no way to really export just the private key and certificate, which can be reimported into the ACS.
However, what you can do is perform a backup of the database. This will save the registry that includes the certificate and the private key. Then you can restore this backup file on a new machine and choose to restore the System Configuration part.This will restore the certificate and private key into the ACS Certificate page.
Tnx,
somishra
