ACS 4.0 Maximum Hostname Addresses
Oct 29th, 2007
I have a an AAA Client Hostname group setup with all IP addresses for a particular location. I have reached a point that whenever I add a new IP address to the group it bumps off the last IP in the replication on the secondary server. The primary accepts the IP address addition and never bumps off a IP from the end. However, the replication is stuck at some maximum number. Is there a limitation?
jsivulka Fri, 11/02/2007 - 07:37
  • Bronze, 100 points or more
ACS aaa client can have a single hostname with more than one ip addresses, in this case, the first ip address will be imported for the hostname. viz. in acs if we have a host with name TESTDEVICE and ip addresses 10.10.10.1 and 10.10.10.2, while importing to DCA, we will import TESTDEVICE with ip 10.10.10.1 as DCA allows only one ip address for a given host.
