10-29-2007 06:02 AM - edited 03-03-2019 05:31 AM
Hi all,
I've got some troubles to make an isdn backup connection working from a branch office in USA to a HQ in Italy.
In any way I can't make the call be successfull if I call from the USA router to Italy, the calls from Italy to Usa works like a charm!!!!
The logs I've got during the failed attempts are the following:
Oct 29 07:30:34.074: ISDN BR1/0 Q931: TX -> SETUP pd = 8 callref = 0x3E
Bearer Capability i = 0x8890218F
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Keypad Facility i = '01139051aaaaaaa'
Oct 29 07:30:34.234: ISDN BR1/0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xBE
Channel ID i = 0x89
Oct 29 07:30:38.298: ISDN BR1/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xBE
Oct 29 07:30:38.830: ISDN BR1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xBE
Cause i = 0x839F - Normal, unspecified
Signal i = 0x03 - Network congestion tone on
Oct 29 07:30:38.834: ISDN BR1/0 Q931: TX -> RELEASE pd = 8 callref = 0x3E
Oct 29 07:30:38.870: ISDN BR1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xBE
Reading the cisco docs it seems that the above error means the carrier doesn't know how to route the call, excluding that I'm dialing the wrong number I can think that the carrier forbids international calls by contract, but the carrier itself keeps telling me that it's not the case.
I've got little experience with Usa isdn lines and I'm really clueless, so I ask for your help.
Here follows a piece of the Usa router config, which is a 2811 with a 4bri interface, the Italy router is a 2821 with a pri interface aboard.
interface BRI1/0
no ip address
encapsulation ppp
no ip mroute-cache
dialer pool-member 100
isdn switch-type basic-ni
isdn point-to-point-setup
isdn spid1 262xxxxxxx0101 xxxxxxx
isdn spid2 262yyyyyyy0101 yyyyyyy
ppp authentication chap
ppp multilink
interface BRI1/1
no ip address
encapsulation ppp
no ip mroute-cache
isdn spid1 262wwwwwww0101 wwwwwww
isdn spid2 262zzzzzzz0101 zzzzzzz
ppp multilink
interface Dialer1
ip address 10.177.254.2 255.255.255.0
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name 2811VPN2
dialer idle-timeout 300
dialer string 01139051aaaaaaa class italy
dialer load-threshold 50 either
dialer-group 2
compress stac
no cdp enable
ppp multilink
map-class dialer italy
dialer isdn speed 56
However both bri interfaces shows the same issue when calling to Italy, but they can succesfully call to each other!!!
Tnx,
Max.
10-29-2007 06:09 AM
Max
It may be especially significant that they can successfully call each other. This would eliminate many potential problems such as faulty hardware or incorrect cabling, or misconfigured ISDN switch. If they can call each other then I do not see that the problem can be on the router or in the router configuration.
I do not have much experience with this, but I suspect that the problem may be in the provisioning of the ISDN by the provider. They may claim that they support international calling (and that probably is true). But it surely sounds like the provisioning of these particular ISDN circuits do not include that feature. I would suggest that you ask the provider to check carefully on the provisioning of these circuits.
Rick
10-29-2007 06:38 AM
Hi Rick,
first of all tnx for your incredibly quick reply!!!
Not only the two lines can call to each other, but they both can receive calls from Italy.
Me too I'm convinced that it has to be a provisioning issue, but the provider keeps assuring the customer that there are no restrictions to international calls regarding those contracts.
In fact the carrier keeps rejecting the calls with the errors you have seen and the calls never come to the Italian side.
By your experience cannot it be an issue related to the different speed of the Italian and north american lines (56k versus 64k)?
I've tried to remove the related class map with bad luck, but maybe it's a carrier or router issue that produces a mesleading error message.
Tnx again,
Max.
10-29-2007 07:01 AM
Massimo,
it is not due to 56/64K, everyone uses 64Kbps.
As suggested by Rick, seems like the provider doesn't correctly route international calls.
One thing they may got wrong is that this is a data call, that is always a little special becase it's ISDN international, they may expect you to do voice calls only.
Does it produce the same error if you do "isdn test call interface ...
10-29-2007 08:33 AM
Hi Paolo,
your name sounds familiar :-)
Yes, it produces the same error if I try with "isdn test call etc...."
All is pointing to a provider issue, but the provider swears to the customer that all is fine ad international calls are allowed, the customer is believing him, all in all the provider is loosing some bargain blocking international calls.
I've got no answers at all.
Tnx,
Max.
10-29-2007 08:54 AM
Hi Massimo,
Then play by the rules, fax or email to telco the trace showing the parameters used during the call and ask the ISP to trace the reason for the call failing.
Remind them that this is a data call, again they may not be prepared to handle that on an international basis. Perhaps the international carrier they are sending the call to, is ultimately responsible.
Tell these things to your customer too and you should be OK.
Perhaps you knew me from some prehistoric age ?
good luck!
10-29-2007 08:58 AM
I've also tried to perform some "isdn test call etc..." to other Italian numbers where I've the control on the routers, but in any case I've seen the call coming.
Tnx again,
Max.
