Authorization Logs in ACS 4.1
Answered Question
Oct 29th, 2007
We have installed new ACS 4.1 appliance. Its working fine for all the logs but authorisation logs are not coming. I have done necessary configuration into AAA clients. Can somebody help on this. Do i need to upgrade the appliance?
Pls suggest...!!!!
Correct Answer by Jagdeep Gambhir about 9 years 2 months ago
You need to apply patch 4.1.1 patch5 to fix it.
Here is the bug info
http://cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsg97429
CiscoSecure ACS for Windows: Download patch:
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Patch filename: Acs-4.1.1.23.5-SW.zip
Readme and installaion instructions: Acs-4.1.1.23.5-SW.txt
For appliance download patch
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
~JG
Please rate helpful posts
Correct Answer by psureshrao about 9 years 2 months ago
Update and install with latest patches available in cisco. it will work. update it to 4.1.1 bulid 23.
Overall Rating: 4 (2 ratings)
Correct Answer
psureshrao Mon, 10/29/2007 - 08:58
Correct Answer
Jagdeep Gambhir Tue, 10/30/2007 - 08:33
~JG
