config file from tftp at startup (6509 with Sup720)
ralph.erhardt
Hi together
I will download the config file for my 6509 with Sup720 from a TFTP Server.
I have configerd the GigabitEthernet 5/2, so I can ping the tftp-server. Also I'm able to down&upload files to the tftp-server.
The configuration looks like:
hostname Testrouter
boot host tftp run 192.168.88.250
boot network tftp run 192.168.88.250
interface GigabitEthernet5/2
switchport
no ip address
media-type rj45
interface Vlan1
ip address 192.168.88.9 255.255.255.0
The service config command is also set!
The big problem is, the router comes up normaly and do not access the tftp-server in any way :-(
Have anyone a idea?
Thanks a lot in advance
Cheers Ralph
lgijssel
Level 9
Level 9
This is from the command lookup tool:
boot host
To specify the host-specific configuration file to be used at the next system startup, use the boot host command in global configuration mode. To restore the host configuration filename to the default, use the no form of this command.
boot host remote-url
no boot host remote-url
Syntax Description
remote-url
Location of the configuration file. Use the following syntax:
•ftp:[[[//[username[:password]@]location]/directory]/filename]
•rcp:[[[//[username@]location]/directory]/filename]
•tftp:[[[//location]/directory]/filename]
Defaults
If you do not specify a filename using this command, the router uses its configured host name to request a configuration file from a remote server. To form the configuration filename, the router converts its name to all lowercase letters, removes all domain information, and appends -confg or -config.
Looking at the config, you might have not correctly specified the required file.
regards,
Leo
I have done it now in this way, but without any improvement! :-(
Here is my config:
(I found the ip tftp ? command!)
hostname Router
boot host tftp://192.168.88.250/run
boot network tftp://192.168.88.250/run
no aaa new-model
ip subnet-zero
ip tftp source-interface GigabitEthernet5/2
ip tftp boot-interface GigabitEthernet5/2
media-type rj45
ip default-gateway 192.168.88.250
I'm able to ping the TFTP Server...
Router#ping 192.168.88.250
Sending 5, 100-byte ICMP Echos to 192.168.88.250, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router#
Have anyone any idea??
Cheers Ralph
ralph.erhardt
Here is my config:
hostname Router
no aaa new-model
ip subnet-zero
media-type rj45
Router#
Cheers Ralph
