isdn failiure
Oct 29th, 2007
UK based, I have a vic2 2bri interface card. running CME 4.1. I cannot make an outgoing call, on either port I get the error Cause i = 0x82E4 - Invalid information element contents. I know that the Isdn line is good as we have used an Avaya system on the isdn2 and that works o.k. layer 1 and 2 is up and switch-type is basic net3.
if anyone has any ideas?
Paolo Bevilacqua Mon, 10/29/2007 - 08:33
Can you send the complete output of "debug isdn q931" ? You must be placing the calls with some wrong parameter, like type national instead of unknown, etc.
silex Mon, 10/29/2007 - 11:22
I have managed to correct the issue.
I needed compand type alaw command in the voice-port interface. many thanks for your help paolo
