CPU Difference between 2811 and 2851?
Oct 29th, 2007
  • Bronze, 100 points or more
do 2800 series routers use the same cpu through out the series (2801, 2811, 2821, 2851) or does it vary?
Is it also the same case for the 3800 series?
Thanks.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 10/29/2007 - 10:56
  • Hall of Fame,
    Founding Member
It varies for each model.
Please see document attached in following file for expected performances.
Hope this helps, please rate post if does!
