SDM remote connection
Oct 29th, 2007
I wondred if someone could tell me if we can manage a router using SDM over Internet. Consequently, do you know which ports are used by the application to let me allow connections through the firewall
best regards
didyap Fri, 11/02/2007 - 09:25
You cannot manage a router using SDM over Internet. SDM can be used in a LAN environment, say VLAN1, then just connect your PC to a switchport that belongs to the VLAN. In the browser you should use the routers ip address.
jeyriku Fri, 11/02/2007 - 16:43
Many thanks for your answer. i've been using SDM in my Lan for a while now.
For my own knowledge, do you know why we cannot use SDM over internet?
Kind Regards,
Jeyriku
