IP routes for a especific IP
Hi;
In a 6506 , can I create a route for a specific IP?
I mean, something like;
For all the VLAN's, I have a default gateway to a Firewall, but I want that some IP's if they go to the internet, they will go to another path.
Something like;
" <ip origin> <ip destination> gateway"
It's possible to configure it in the 6506?
Thanks. Regards
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Mon, 10/29/2007 - 09:52
  • Green, 3000 points or more
Eneko, you would need policy base routing..
two examples bellow, also posible on 6506 as long you have routing engine .
Example on routers
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
On L3 switches
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a00802135d3.shtml
Pls rate any helpfull posts
Jorge
