No Data on Netflow
Oct 29th, 2007
I've configured netflow to export data to a correct ip and port number. I doubled and tripled check both sides. And both show the the destination ip and port is ok. SNMP community is doubled check and everything on that side is ok. When I run the sho ip flow ex it comes up with 0's. Any suggestions?
julienf28 Tue, 10/30/2007 - 03:14
I did the ip flow ingress egress and enabled the interface itself and everything worked great. thx
Jan Nejman Tue, 10/30/2007 - 01:30
  • Bronze, 100 points or more
could you send me your netflow configuration?
i.e.:
show running | inc flow
show running | inc mls
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
