This is what I hate about practice tests!!
Oct 29th, 2007
Took a practice ICND (640-811) exam from the Cisco site. When I finished it returned a list of the questions with a legend of blue checkmark for correctly answered questions, a red X for incorrectly answered questions. Additionally, an ANSWER with a box around it is supposed to indicate the correct answer.
My results returned questions 1-75 with EVERY SINGLE ANSWER marked incorrectly (red X). The correct answer is NOT indicated.
How am I supposed to use this as a training tool? If Cisco has it wrong, where do I go???
pipemajor Mon, 10/29/2007 - 11:41
Example - 1st Question:
Legend
answer Correct answer
Your answer, Correct.
Your answer, Incorrect.
1. On a Cisco router, what information does the show ip protocols command display?
Interface information
Values of routing timers
The contents of the routing table
Class of the current routing protocol
I chose "Values of routing timers" and the result marked it INCORRECT. But nowhere does it indicate what the correct answer is supposed to be... I write the real exam in a week...
Wilson Samuel Mon, 10/29/2007 - 11:48
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
In my humble opinion the BEST way to conquer any Cisco Exam is to go thoroughly through the Blue Print (using cisco.com) and once you know the stuff, attempt.
Its pretty easy, than the other tools which generally are not quite helpful
All the BEST!
Wilson Samuel
pipemajor Mon, 10/29/2007 - 11:53
Thanks for the reply. If by "Blue Print" you mean the Exam Topics, yes, I have those. Just frustrated by these "helpful" tools which turn out not so helpful after all.
I do have the Transcender kit for this exam. Hope that is of better value...
rayroyaleverest Tue, 10/30/2007 - 05:12
I like the Cisco Press ICND text with the associated CD which includes simulations. Sybex also publishes some good material.
