ASA 5500 U-turn
Oct 29th, 2007
I am trying to set up an ASA 5500 to do some routing. We have a couple of networks on the inside, and I am trying to use the router as the gateway address for one of them. It has routes to all the networks and I added the " same-security-traffic permit intra-interface" command gut that did not work. Am I missing something?
Thank you,
Joel Friedman
Jon Marshall Mon, 10/29/2007 - 11:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Joel
At the risk of stating the obvious, the interfaces do actually have the same security level ?
If so it could be a NAT issue - could you post config if at all possible.
Jon
jfriedman Mon, 10/29/2007 - 11:35
I am coming in and out of the same interface (inside). I am not sure if I can post the configuration, even sanitized, as it belongs to a customer of mine.
Joel
acomiskey Mon, 10/29/2007 - 11:38
  • Green, 3000 points or more
This should be one way to get it going...
global (inside) 1 interface
nat (inside) 1 0 0
